INSTAR MQTT Alarmserver Interval
Q: After I changed completely to MQTT, I switched off the
HTTP alarm server
on my 9008. This had the consequence that the cool-down interval was deactivated. As a result I am getting tens of
MQTT alarm messages
per alarm event. I think the option to set the rest interval would also be useful for MQTT.
Mike Polinowski
INSTAR MQTT
Firmware Update
Full HD Series
INSTAR Deutschland GmbH
INSTAR MQTT
INSTAR MQTT
Mike Polinowski
IFTTT Applets
Firmware Update
Full HD Series
INSTAR IFTTT Applets
INSTAR IFTTT
A: Since you usually receive the MQTT alarm server in a Smarthome and define your own actions there, we decided to set the interval as small as possible (1s). So it is intended that you can define your own cool-down interval for the actions in the Smarthome.
You can also adjust the interval of the MQTT alarm server directly on the camera. You can read out the current status on your camera with the following
CGI Command
/param.cgi?cmd=getmdalarm&-aname=server3
The default settings are there:
var md_server3_switch="on"; var md_server3_interval="1";
If you now want to set the interval to, for example, 5 seconds you can do this with this command:
/param.cgi?cmd=setmdalarm&-aname=server3&-switch=on&-interval=5
You get an OK from the camera and the value should now look like this:
var md_server3_switch="on"; var md_server3_interval="5";
