Installation without a PC
Q: Is it necessary to install the camera on the PC or is the app for the smart phone also sufficient?
A: As a first installation you should definitely use a PC with a web browser to make the basic settings and scan the QR code with the Instar app. After initial setup, you can then conveniently control the camera via your Smart Phone.
This is the default Markdown Footer
