INSTAR Deutschland GmbH
Deactivate Camera
Q: Can the camera be turned off by app?
A: The camera can only be turned off by disconnecting it from the power. However, it is possible to remotely disable the alarm function of the camera via the app. You can also set schedules for alarm recording or manual recording. Alarm schedule app functions (using the example of the iPhone app)
